It is currently Sun Aug 17, 2025 8:14 pm
PostPosted: Sat Sep 27, 2014 9:24 pm
First name: Doug
Last Name: Balzer
City: Calgary
State: Alberta
Watch the quilt on this Sapele parlour guitar stand up and say hello using West System Epoxy.
http://youtu.be/TdLpeob302o
Doug
PostPosted: Sat Sep 27, 2014 9:41 pm
First name: sam
Last Name: guidry
State: michigan
Country: us
How many coats do you do?
PostPosted: Sat Sep 27, 2014 9:49 pm
First name: Doug
Last Name: Balzer
City: Calgary
State: Alberta
3 coats and then sanding in between with 220 RO sander. The first coat just gets soaked up and seals the wood. The next two levels and fills the pores.
Doug
PostPosted: Sat Sep 27, 2014 9:54 pm
First name: Heath
Last Name: Blair
City: Visalia
Ummm, yeah, that's gorgeous.
sweat the small stuff.
PostPosted: Sun Sep 28, 2014 12:40 am
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
Beautiful wood, for sure. Pore filling isn't my favorite step but I'm not using epoxy. Looks like the epoxy goes on easy. How hard is it to hand sand assuming you do a good job of removing the excess?
PostPosted: Sun Sep 28, 2014 5:51 am
That sure does pop the figure, gorgeous!
PostPosted: Sun Sep 28, 2014 8:21 am
First name: Doug
Last Name: Balzer
City: Calgary
State: Alberta
If one is careful to remove the excess the sanding goes quite quickly.
Doug
PostPosted: Sun Sep 28, 2014 8:40 am
First name: Tom
Last Name: West
State: Nova Scotia
Doug: Wonder if you have also used Zpoxy and if you have, could you comment on any pluses and minuses? Beautiful looking guitar by the way.
Tom
PostPosted: Sun Sep 28, 2014 8:51 am
First name: Doug
Last Name: Balzer
City: Calgary
State: Alberta
Tom
Thanks Tom. I have tried no other products so I am not in a position to offer comparisons. However I picked up the idea and method from the venerable Todd Stock who used zpoxy. I believe you can still find his video of this on youtube.
Doug
PostPosted: Sun Sep 28, 2014 9:33 am
You sure wouldn't like the way I do it...
PostPosted: Sun Sep 28, 2014 10:04 am
First name: Tom
Last Name: West
State: Nova Scotia
Doug: I've used Zpoxy and also seen Todd video. Your epoxy seemed a bit thinner and seemed to flow very easily. Do you thin or heat before applying?
Tom
PostPosted: Sun Sep 28, 2014 10:12 am
First name: Patrick
Last Name: Hanna
State: Missouri
Doug,
You've obviously got your application process mastered and I don't think anyone can argue with your results on that guitar. I've never used epoxy as a filler. I've read about it countless times but have always shied away from it for one reason or another. You make it look very easy. Thanks for posting your video.
Patrick
PostPosted: Sun Sep 28, 2014 10:13 am
First name: Doug
Last Name: Balzer
City: Calgary
State: Alberta
Tom
I neither heat or thin. West System 105/207 comes quite thin as it is made for fiberglassing boats, etc.. It is my unqualified opinion that an epoxy seal/pore-fill adds a layer of depth and enhancement of wood figure that some other methods cannot achieve to the same degree.
Doug
PostPosted: Sun Sep 28, 2014 10:24 am
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
I have built 4 now and am not a fan of a mirror finish. I don't fill completely and prefer the look of some open grain. Over last weekend I was in my daughter's shop in Brooklyn and she had a Fraulini 12 string in for a minor issue and I got to see what Todd Cambio does first hand. He uses varnish sprayed and does what appears to be no grain filling. The guitar has a nice amount of gloss, but is no where near shiny, and the open grain was very obvious. Not sure what wood it was as it was stained dark with a mild sunburst on the back, but from the inside looked like it might have been a mahogany. I see my future.
Ed Minch
PostPosted: Sun Sep 28, 2014 10:41 am
First name: Danny
Last Name: Vincent
Nice wood Doug. Is that faux "The Tree"? :lol: That's going to be a great looking guitar. Where did you get the back and sides?
PostPosted: Sun Sep 28, 2014 11:40 am
First name: Ringo
Pore filling is by far my least favorite step, but a necessary evil if one wants to sell a guitar in this day and age. Epoxy does a great job of popping the figure and 'wetting' the wood for sure.
Tom
I've used both. Zpoxy's mix ratio is definitely more forgiving and it seems to sand easier, but that may be at least in part due to my process being a lot cleaner than it was back when I used to use West System. Another difference, though subtle, is a slight amber color that Zpoxy adds where West System is clear. Both work well when used properly. Note that there are different formulations of Zpoxy... you want to make sure to use the Finishing resin.
PostPosted: Sun Sep 28, 2014 11:41 am
First name: Doug
Last Name: Balzer
City: Calgary
State: Alberta
I bought it from Mike Rosendahl through the OLF Classifieds (worth subscribing to). He bought it from RC Tonewoods.
Doug
PostPosted: Sun Sep 28, 2014 1:44 pm
First name: Casey
Last Name: Cochran
City: Gainesville
State: GA
Zip/Postal Code: 30501
I used Z-poxy on my first few guitars and though they were slick when freshly buffed, they all have visible pores as the epoxy has shrunk. Has anyone else encountered this? I used Cardinal paste filler on one and it was user friendly and stable but I'm not fond of the look. On my latest build I pore filled with shellac. It was quite labor intensive (must have taken 15-20 wiped on coats) but it made a rather pedestrian set of EIR really pop.
Good judgement comes from experience. Experience comes from poor judgement.
PostPosted: Sun Sep 28, 2014 2:43 pm
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
Zip/Postal Code: J2M 1R5
Yes. Tried two different lots of Zpoxy with same disappointing results within 6 months. Switched to West System with no change in application technique and problem disappeared.
PostPosted: Sun Sep 28, 2014 2:45 pm
First name: Casey
Last Name: Cochran
City: Gainesville
State: GA
Thanks, Tim. Good to know.
PostPosted: Sun Sep 28, 2014 2:49 pm
City: Tyler
Casey, you are stating what I seldom see stated, on any forum. There is no perfect, shrink proof filler product or technique. I've tried most all I have read about, including three types of epoxy, CA glue, waterborne, and traditional paste. Haven't tried eggs or drywall compound.
I have to some degree or another seen pores later, from 6 months to a year later and in varying degrees (sometimes just in one area sometimes all over).
It also depends on how thick my final finish is (I use nitro). It is odd that you have then on all guitars you have built. Try another coat of epoxy next time and don't sand back to wood if you are doing that. See how that works.
PostPosted: Sun Sep 28, 2014 8:47 pm
First name: Wendy
Last Name: W
State: Arizona
Casey, do you sand between those 15-20 coats of shellac? What cut of shellac are you using?
Thanks, Wendy
PostPosted: Mon Sep 29, 2014 6:30 am
First name: Casey
Last Name: Cochran
City: Gainesville
State: GA
Wendy, there were probably three sanding sessions with 320 dry before the pores were filled. I didn't measure the cut, but on the recommendation of a friend I put the flakes (super blonde) in a jar and covered them with twice as much alcohol. A thinner first coat helps seal the grain.Image
PostPosted: Mon Sep 29, 2014 7:08 am
First name: Casey
Last Name: Cochran
City: Gainesville
State: GA
Not that it makes much difference, but I'm using blonde dewaxed flakes from shellac shack, not super blonde. I also used less alcohol as the process went along.
PostPosted: Mon Sep 29, 2014 7:42 am
That must be seriously heavy shellac to fill pores in a few sessions. It used to take me the best part of two weeks and that was with leaving the shellac sanding dust filling the pores.
Users browsing this forum: dan2087 and 39 guests
